SeaNo180
Ultimate Turbo Reference guide for Nissans.
Recommended Posts
This is a thread for people who are buying a new turbo to be able to see what other guy's are using and what power figures they are making with what mods.
Make and model:
Size of engine:
Modifications to the car:
Type of turbo:
Trim of turbo:
Rear Exhaust housing:
When does vehicle begin boost:
When does vehicle reach full boost and what PSI:
Does the vehicle have Cams? if so;
What brand:
What lift/duration etc:
Max power achieve at what boost:
Also feel free to post up Dyno sheets aswell.
This thread is for references only, so can people please post up their mods and what power they are making with their aftermarket turbo's. we dont' need any posts with standard turbo's.
There is to be no discussion, this is a reference thread only. if you want to ask any questions please pm the member. any discussion will be deleted.
Also please use the template provided, just copy and past into your new post. this will make browsing and searching easier.
Share this post
Link to post
Share on other sites
Make and model: Pulsar GTiR
Size of engine:SR20DET
Modifications to the car: exhaust, FMIC, pod, EBC
Type of turbo: Garrett GT2871R
Trim of turbo:56
Rear Exhaust housing:0.86
When does vehicle begin boost:2,500rpm (ish)
When does vehicle reach full boost and what PSI:approx 3,800-4,000rpm, 15psi
Does the vehicle have Cams? no
approx 190kw at all fours at 15psi
Edited by babygtr93
Share this post
Link to post
Make and model:sil80 sr20det
Size of engine:2.0
Modifications to the car: exh, fmic,fuel pump, safc2, clutch,bov
Type of turbo: gt28rs disco potato
Trim of turbo:??
When does vehicle begin boost: 2400rpm
When does vehicle reach full boost and what PSI: 3250 13psi
Does the vehicle have Cams? if so; soon
What brand:
Max power achieve at what boost:220 @12.5
Share this post
Link to post
Make and model: s1 s14
Size of engine: 1998cc
Modifications to the car: cooler,power fc, cams, z32, exhaust manifold, 3" exhaust, water spray, pod, cold air intake, avcr, bov, fuel pump
Type of turbo: garret gt2535r
Trim of turbo: 56
Rear Exhaust housing: .86
When does vehicle begin boost: 2500-2800
When does vehicle reach full boost and what PSI: 3000-3200 1bar
Does the vehicle have Cams? yes
What brand: hks step 1's
What lift/duration etc: 256(in) 264(ex)10.5mm
Max power achieve at what boost: 236@ 1.2bar
:o
Share this post
Link to post
Make and model: 200sx 1999
Size of engine: 2.0L
Modifications to the car: Lots
Type of turbo: GT2871R
Trim of turbo: 52
Rear Exhaust housing: .64
When does vehicle begin boost: 1500rpm
When does vehicle reach full boost and what PSI: 3400rpm
Does the vehicle have Cams? if so; no
What brand:
Max power achieve at what boost:so far 210rwkws @ 1.2bar tune not finished !
Share this post
Link to post
Make and model: 90 S13 Silvia
Size of engine:1.8
Modifications to the car:gt28r,fmic,040 fuel pump,exhaust,SS manifold,bov,injectors,afm,ebc, Dr Drift Remap
Type of turbo: GT28R
Trim of turbo:
When does vehicle begin boost:2200
When does vehicle reach full boost and what PSI:3500 14.7
What brand:
Max power achieve at what boost: 172rwkw @ 1 Bar
Share this post
Link to post
Make and model:Nissan 180sx
Size of engine:2.6
Type of turbo:GT28r x2
Rear Exhaust housing:.64
276rwkw on standard injectors.
Share this post
Link to post
Make and model: Nissan 180SX
Size of engine: SR20DET 2.0 litre
Modifications to the car: front mount cooler, pod, exhaust, fuel pump, remap.
Trim of turbo: dunno
Rear Exhaust housing: dunno
When does vehicle begin boost: 2000
When does vehicle reach full boost and what PSI: 3500 - 3800
Max power achieve at what boost: 180.4rwkw @ 15psi
Share this post
Link to post
Make and model: 95 S14 200SX
Size of engine: SR20DET 2.0L
Modifications to the car: PFC Djetro,FMIC,pod custom aluminium air box,custom hi-mount manifold ported ceramic coated turbo back exhaust,HKS 3037s ext gate,tial 44mm gate,tomei poncams/ras/adjustable cam gears,nismo 740cc,040,rising fpr,sr20de na tb,hybrid ebc,brass button, lightened flywheel
Type of turbo: HKS 3037S
Trim of turbo: 56trim a/r .60
Rear Exhaust housing: .87
When does vehicle begin boost: 3000rpm
When does vehicle reach full boost and what PSI: 4200rpm 17psi
Does the vehicle have Cams? if so; yes
What brand: Tomei poncams
What lift/duration etc: 11.5mm 256/256
Max power achieve at what boost: 243.9kw@17psi, bout 327rwhp I think
Now running Power Fc D-jetro pro making 245kw on 17psi :D
Share this post
Link to post
Make and model: S15
Size of engine: 2L
Modifications to the car: FMIC, 3inch exhaust, Power fc, Z32 afm, 740cc injectors, walbro 255ltr, blitz id3...
Type of turbo: Garrett GT28rs
When does vehicle begin boost: 3500
Does the vehicle have Cams? if so; Yes
What brand: HKS step 1
What lift/duration etc: intake 256 exh 264
Max power achieve at what boost: 220.6rwkw @17.2psi
Share this post
Link to post
Make and model: Nissan 180sx 1994
Size of engine: 2L
Modifications to the car: FMIC, Full 3.5" exhaust (dump,front,catback) GTR fuel pump, s15 injectors, rb20 afm, pod, turbotech boost controller, dr.drift ecu
Type of turbo: Garrett GT28RS (disco potato)
Trim of turbo:
When does vehicle begin boost: 2200
When does vehicle reach full boost and what PSI: 3200
Does the vehicle have Cams? NO, only standard
Max power achieve at what boost: 202.8rwkw@17psi
Share this post
Link to post
Make and model:180sx
Size of engine:1jz 2.5ltr
Modifications to the car: exhaust , fmic,fuel pump, safc2, clutch,bov
Type of turbo: t60-1
Trim of turbo:??
Rear Exhaust housing:0.64
When does vehicle begin boost: 2000 rpm
When does vehicle reach full boost and what PSI: 3750 17psi
Does the vehicle have Cams? if so; none
What brand:
Max power achieve at what boost:255rwkw @ 17psi
would be alot more if i have after market ecu
Share this post
Link to post
Make and model: Nissan S14, engine is S15
Modifications to the car: PowerFC D-jetro, 740cc injectors, tomei fuel pump, 1.1mm headgasket, 2 core FMIC
Type of turbo: Trust TD06S-20G
Rear Exhaust housing: 8 cm2
When does vehicle begin boost: not for sure
When does vehicle reach full boost and what PSI: ~4800rpm @ 1.4bar
What brand: Tomei
What lift/duration etc: 260/12.0mm
Max power achieve at what boost: 309rwkw at 1.4bar
Share this post
Link to post
Make and model: SR20DET
Size of engine:2L
Modifications to the car: Heaps
Type of turbo: GT2871r
Trim of turbo:56 trim
Rear Exhaust housing:0.86exh
When does vehicle begin boost:2500
When does vehicle reach full boost and what PSI:4000rpm and 18psi
Does the vehicle have Cams? if so; NO, not yet
What brand: ---
What lift/duration etc: ----
Max power achieve at what boost: 210.2 kw @ wheels on 16.5 psi
Share this post
Link to post
Size of engine:2L
Modifications to the car: PFC, FMIC, BOV nismo 555 injectors, walbro pump , full exhaust
When does vehicle begin boost:2700
When does vehicle reach full boost and what PSI:4000rpm and 1.1bar
Does the vehicle have Cams? if so; No
What brand: ---
Max power achieve at what boost: 207.0 kw @ wheels on 1.1bar
(had to stop tunning due to my car but will be back on soon. from all reports should get 230ish)
Share this post
Link to post
Make and model:Nissan 180sx with s15 front
Size of engine: 2Lt rb20
Modifications to the car: Heaps of bolt on's
Type of turbo:gt30r
Trim of turbo: .7
Rear Exhaust housing: .63
When does vehicle begin boost: 2300rpm
When does vehicle reach full boost and what PSI: 4100rpm
Does the vehicle have Cams? No
Max power achieve at what boost: 241.3rwkw@17psi
Share this post
Link to post
Since I get a stack of PM's with these questions hopefully this will be helpful to some of u.
Make and model:S15 200SX
Size of engine: SR20DET - If you dont know the size of an sr20, u must be on the wrong site!
Modifications to the car: Check signiature
Type of turbo: Garrett 2871r
Rear Exhaust housing: .86 housing
When does vehicle begin boost: need to check
When does vehicle reach full boost and what PSI: 3750rpm
What brand: Tomei Poncams
What lift/duration etc: 256 11.5mm in&out
Max power achieve at what boost: 258kw@17psi
Share this post
Link to post
Make and model: S15 Sr20det
Size of engine: 2L
Modifications to the car: sr20 na cam, tomei cam gear set to 0 + usuals
Type of turbo: gt2871r
Trim of turbo: 56t version
When does vehicle reach full boost and what PSI: 4000rpm 1.2bar
Does the vehicle have Cams? if so; sr20 na ehaust
What brand: nissan
Max power achieve at what boost: 208rwkw 1.2bar & boost spike @ 6000rpm
13.2 @ 113mph
Share this post
Link to post
Make and model: S15
Engine: SR20DET
Modifications to the car: Trust R-SPL HG intercooler, APEXi Power Intake on custom intake piping, HKS FCon V Pro, 740cc injectors, HPI 4-1 manifold, HKS turbine outlet, Fujitsubo 76.3mm front pipe, Kakimoto 80mm cat straight through pipe, HKS Hi-Power exhaust (85mm piping)
Type of turbo: Garrett GT2860RS ("Disco Potato")
Rear Exhaust housing: 0.86 A/R
When does vehicle begin boost: 3300 rpm
When does vehicle reach full boost and what PSI: 4000-4300rpm, 1.3 bar
Cams: Standard S15 SR20DET
Max power achieve at what boost: 1.3 bar
347 hp @ the wheels, 61.1kgm of torque (~600Nm)
Share this post
Link to post
Make and model: Nissan 200SX S14a
Modifications to the car: to many
Type of turbo: Garret GT2860RS
Trim of turbo: -
When does vehicle begin boost: 3200
Does the vehicle have Cams? if so; standard
What brand: -
Max power achieve at what boost: 242.3rwkw on 16psi
Share this post
Link to post
ake and model: Nissan s13 silvia
Modifications to the car: bolt ons
Type of turbo: hks Gt ss
Trim of turbo: -
When does vehicle begin boost: 2700
When does vehicle reach full boost and what PSI: 3800
What brand: -
Max power achieve at what boost: 196kw on 13 psi
Share this post
Link to post
Make and model: 180sx
Size of engine:2l
Modifications to the car: ecu, injectors etc...
Type of turbo: tomei b7652
Trim of turbo:52T
When does vehicle begin boost:?
When does vehicle reach full boost and what PSI:?
Does the vehicle have Cams? if so; nope
What brand:
Max power achieve at what boost: 209.1rwkw @ 16psi
Share this post
Link to post
Make and model: Nissan, S14
Size of engine: 1998cc (sr20det vct)
Modifications to the car: alot...
Trim of turbo: 56
When does vehicle begin boost: can't remember
When does vehicle reach full boost and what PSI: no idea..
CAMS
What brand: HKS STEP 1
Max power achieve at what boost: 243 RWKW @ 14 psi... so far
Look in 'my garage' for dyno sheet.
Share this post
Link to post
Make and model: 88 S13 Silvia
Size of engine: 1.8L CA18DET
Modifications to the car: 3" exhaust, boost controller, r32 GTS-t radiator, thermos
Type of turbo: Garrett T28 Ball Bearing (S15 JDM)
Trim of turbo: T28 Stock
Rear Exhaust housing: T28 Stock
When does vehicle reach full boost and what PSI: 4000-4200rpm 13psi
What brand: -
Max power achieve at what boost: 130rwkw @ 13psi, factory ignition/fuel system and no FMIC yet
T28 died, now running T25G with a FMIC and 15psi. not dynoed yet
Share this post
Link to post
Make and model:180SX Type X
Size of engine:2.0 litre
Modifications to the car:cat back exhuast + pod
Type of turbo: stock t25G
Trim of turbo:stock
Rear Exhaust housing:??
When does vehicle begin boost:2600rpm
When does vehicle reach full boost?4000rpm
and what PSI:9
What brand:
Max power achieve at what boost: 133.9rwkws on 7psi
Make and model: SR20DET Silvia 91
Modifications to the car: Pod/Exhaust/FMIC/Fuel Pump/Bov
Type of turbo: Stock T25g
Trim of turbo: -
Rear Exhaust housing: -
When does vehicle begin boost: 2100
When does vehicle reach full boost and what PSI: 2700 @ 13psi
Hey mate what sort of power are you making?
Share this post
Link to post
Make and model: 1990 Nissan 180SX
Size of engine: 2L
Modifications to the car: 555cc Nismo Injectors, Bosch 040, Wolf3D V4 ECU, 600x300x76 FMIC, GT28RS 0.86, 3" Zorst, more more more.
Type of turbo: GT28RS
Trim of turbo: 76
What brand:
Max power achieve at what boost: 314.9rwhp / 234rwkw
just want to know how to turbo power is rated coz thinking of getting one . i know is rated as horse power but is it at the flywheel or at the wheels , so when they say the turbo is 400hp is it at the engine or at the wheels ?
This topic is not for discussion posts, see the first post. Reference topic only, no discussion. It is rated at the wheels but is not an exact number as there are too many variables between when power is created at the crank and by the time it gets to the bitumen.
Share this post
Link to post
Make and model: 89 240sx Coupe
Size of engine: SR20DET Redtop
Trim of turbo: 56 Trim
Rear Exhaust housing: .86 A/R
When does vehicle begin boost: <2500rpm
When does vehicle reach full boost and what PSI: 20psi @ 4500rpm
What brand: HKS 264 Step 1 Cams
What lift/duration etc: 264 Duration, 10.5mm Lift
Max power achieve at what boost: estimated; 400whp @ 20psi, 400+whp @ 24psi (Dyno will come shortly)
Edited by KB240SR
Share this post
Link to post
Make and model: Nissan 200SX S14A
Size of engine: 1998cc or 2L
Modifications to the car: Hmm...
Type of turbo: TD06 L2 20G
Rear Exhaust housing: 8cm 2
When does vehicle begin boost: 2800
When does vehicle reach full boost and what PSI: 4400 @ 18 PSI
What brand: Tomei Ponams stage 1
What lift/duration etc: 256 in 256 exh 11.5 lift
Max power achieve at what boost: 262.8 rwkw @ 18 psi. Car has recently had boost wound up more and can crack 270rwkw hopefully.
Share this post
Link to post
Make and model: 1990 s13
Size of engine: sr20det
Modifications to the car: z32, full exhaust, walbro pump, pod, hybrid cooler, remapped ecu, stock injectors
Trim of turbo:
When does vehicle begin boost: around 3000
When does vehicle reach full boost and what PSI: ~4000
What brand:
Max power achieve at what boost: 185kw @15psi
Share this post
Link to post
Size of engine: ca18det (1.8L)
Modifications to the car:Rb20 turbo, gtr fuel pump,smallish fmic, exhaust maybe some other stuff
Type of turbo:T03/T04
Trim of turbo:unsure
Rear Exhaust housing:unsure
When does vehicle begin boost:2500-2800
What brand:
Max power achieve at what boost:125kw at 9.5psi
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
