Sign in to follow this
davidg2152
RSP13 180sx fuel tank leaks
Recommended Posts
Took the race car out today and didnt last 1 lap. Got kicked off for a leaking tank. It appears to have stemmed from the cradle atop the tank. I recently added a new Taarks seal and new efi hoses and clamps. Did it all up and it weaps ALOT of fuel from the cradle. Almost like it is pushing up through the screws etc.
Made a hell of a mess and had no track time.
Is there a trick or have I neglected something. I have no idea what else to try.
Dave
Share this post
Link to post
Share on other sites
mosst likly pinched the O ring or fuel has got on it while installing and it expanded
Old 13 did the same after I tried to reuse an old O ring that got soaked in fuel, expanded, then wasnt seating properly and got pinched
Share this post
Link to post
I'd also suggest you check that the breather tube [connecting the tank to the Charcoal Cannister] isn't blocked. Disconnect it, blast the tube clear with an air compressor, then blast air through the tube and confirm that it vents through the Charcoal Cannister.
Share this post
Link to post
And always put the O-Rings in the freezer while you are working on the fuel tanks and take them out of the freezer just before you are ready to put back in to seal fuel tank.
This stops the O-Ring from expanding then causing fuel leaks when put back in . PS suggest to wrap up O-Ring in Kitchen Paper Tower b4 placing in Freezer this stops grief from Mum / GF / Partner
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
