Sign in to follow this
Sr20AU
Normal Dyno figures?
Recommended Posts
Yo, so my s15 originally was an sr20de i bought a sr20det engine put it into my s15 that was already been put together.
Specs
GT2871R - that blew up after being tuned on the dyno it got taken for a test run right after the tune and blew up coming back to the shop. Since then bought a brand new GT2871R From garrett and havn't taken the car back to get it retuned on the brand new Turbo. JNot sure on trim and such but i do have all part numbers to find out if your curious.
740CC nismo injectors
DW300 fuel pump
Z32 AFM
Spit fire coil packs
Stock airbox
Stock BOV
Front mount intercooler
Tomei Cam's 260/11.20
3inch exhaust
i paid 4K for the engine running and all that has 93K on the clock.
cars running on 14PSI on this dyno test. I want to know what else i can do to produce more power and is this normal figures all this is on a NISTUNE BOARD. if it is pretty low power for the mods the engine has installed on it could it be due to the turbo being on its last breath why it had such low figures then blew up straight after the tune then test ran.
Edited by Sr20AU
Share this post
Link to post
Share on other sites
Firstly, all dyno's are calibrated differently, so it's possible this is a low reading dyno.
Looking at your boost curve, it tails away quite considerably towards the top end.
Despite your peak boost pressure being 14psi, it drops down to about 11.5psi by redline.
What are you using for boost control?
I believe the stock BOV is prone to leaking pressure once boost is raised too.
Share this post
Link to post
Thanks for the reply
Sweet it was a Hub dyno if that makes a difference.
I've got a Stock BOV that runs into a turbo smart boost Tee straight into the cooler piping if thats what you mean.
Share this post
Link to post
It might be worth investing in an electronic boost controller.
Features like adjustable gain will allow you to prevent that high RPM boost drop off.
But perhaps you should run the car on the dyno again with the new turbo first.
Edited by 200VIA
Share this post
Link to post
Yea i'm really curious to see if the new turbo would make a difference at all. Since the old turbo was obviously on its way out if it blew up literally right after the tune on a test run around the block. i might have to invest into a Boost controller aswell im just curious with my setup i heard the car should push 220-240kw at ease at like 18-20PSI. why im asking some questions about why it was 190 even if the dyno shows lower figures its still not 220kw atleast lol
cheers for the reply
Edited by Sr20AU
Share this post
Link to post
Skylight is fixed for the enrolment with the perpetual terms for the citizens. The enduring tips of the ukessays are shared for the major chunk for the passages. The role is ensured for the timely provision for the youth of the regions.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
