Sign in to follow this
Papas
KE70 - Advice
Recommended Posts
Hey guys just wondering if there are any little things i could be doing to my standard KE70 to give it a little bit more go without throwing in another motor??
If anyone can help that would be fantastic.. :)
Not after ground breaking speeds just a little more push lol..
Thanks!
Share this post
Link to post
Share on other sites
-remove excess weight
-replace plugs, leads, filters and oils ( if you haven't already)
-2" exhaust with extractors
-bigger carby (32/36 weber)
-cam
-advance timing tune
on a mates car it saw 88hp atw
edit: and manual conversion if auto, as the auto box sucks giant wang
Share this post
Link to post
sure is an auto lol....
much to do to convert it to manual....
ive got a gearbox and the pedal box...
is that all i need?
Share this post
Link to post
you will also need the tailshaft from a manual car, a clutch cable, and to plug in the reversing lights
other than that its just bolts and alot of swearing haha
oh and the flywheel and clutch from a manual keto
Share this post
Link to post
pump tyre pressure up in the rear wheels.
+ can of rp7 for skids
Share this post
Link to post
beter carby as the stock 4k carb is crap,dont spent heaps on the 4k(like i did)just slap a smallport 4age in it. :thumb::thumb:
Share this post
Link to post
-cam
that's not bad power
Share this post
Link to post
ok after weighing it all up.... What is the cheapest conversion to do?
Share this post
Link to post
well no need... :P got the s15!!! ummm seriously... want a cheap little track car!!!
Share this post
Link to post
haha... an auto ke isnt the way to go about it then.
peddle box - 200
gearbox - 300
clutch - 150-200
master/slave - 50
tailshaft - 50
so thats 800 bucks to do manual shit... and its still slow.
seriously.. sell it and get a cheap manual SR20de s13 or something. 2-3K max
Share this post
Link to post
peddle box - 200
gearbox - 300
clutch - 150-200
master/slave - 50
tailshaft - 50
Listen to the man above.
Only way for an auto KE to go quick and cheap these days is for to be driving down a hill.
4AGE conversion is the cheapest conversion to give any decent power and the conversion I did 2(?) years ago now, set me back $3k with labour all done by myself and parts... most of it bought cheap.
You're better off buying a s13. They can be had for so cheap these days.
Share this post
Link to post
Ok sweet as guys! thanks for the help! :)
I can get all the above manual stuff for 200$ off a friend.....
Share this post
Link to post
yeah prices i listed were general forum prices. ive sold peddle boxes for 200 alone. if u can get everything for 200 then y0ur laughing.
Share this post
Link to post
peddle box - 200
gearbox - 300
clutch - 150-200
master/slave - 50
tailshaft - 50
just out of curiosity does it need and engineering certificate because your replacing the KE70 cross members... and they don't hold a 4AGE as far as I'm aware of... I know the 4AGE bolts straight onto cars with a 4AC... but I understand you need to use cross members from a AE71 and like cut them down or something... am I right???
Share this post
Link to post
no. the ae71 and ke70 are the exact same chassis. just differnt drive trains.
so ae71 crossmember bolts straight in
Share this post
Link to post
peddle box - 200
gearbox - 300
clutch - 150-200
master/slave - 50
tailshaft - 50
It technically needs an engineers certificate to have a 4age in a ke70/ae71 chassis as well as ADM ae86s for that matter. Only because the 4age was never released in Australia in that car or some crap. There was a massive debate about it and in the end, you need an engineers certificate for it to be legal.
To fit a 4age into the ke70, all you need to do is get an A series engine cross member (either from an ae71 or ae86) and it should bolt straight in. There's no need for any cutting.
Only thing I ever cut to fit the 4age into my ke was a hole for the clutch master cylinder and maybe my hand a few times :P
Share this post
Link to post
Simon the pedal boxes that go for $200 are the hydraulic ones from AE71/TE72, KE70 ones aren't worth shit coz they're cable clutch. Unless these days people are spending $$$ on shitty auto KE70s, wouldn't suprise me
Share this post
Link to post
Yeah, I think he meant that by listing the other stuff needed as well, slave and master cylinder.
But yeah, $200 for a normal cable clutch pedal box, LOL I wouldn't be surprised..
Share this post
Link to post
just sell and buy another manual ke. cheaper.
then just
mod the airbox
run 15o timing
bp98 ron fuel
extractors
exhaust
lock diff
suspension
modded knuckles ;)
my car goes pretty hard with just these mods. can slide it in the wet or dirt easily
Share this post
Link to post
I gotta 4k-c in my ke55.....
Don't Upgrade anything unless you plan to upgrade everything. The stock cam, carby and exhaust manifold are all pretty well matched together, i pulled off my exhaust (after the first hotdog), took my air filter off, set my rocker rollers real good n shit (do it when the motor is hot), advanced the timing to something stupid like >20deg, played with the carby and did all the normal maintenance shit (new points, new coil, oil, filters etc) The result was my motor sounded like a 12a bridgeport and ran really well (for a 4k). Had enough power for fat skids in the hills and I have pics to prove it haha!
I've now got a 32/36 weber, fat cam of some description and 4-1 extractors... I put them on one by one and I can say its not worth it to upgrade just the cam or just the carby, you have to do the whole lot.
K motors are underated, if you do them right they are a great little motor for little cars.
Share this post
Link to post
sounds pretty much what my mate did
certainly surprises people when you tell em its only a little 4k under the hood :lol:
Share this post
Link to post
big cam, high compression efi, turbo, gilmer belt drive cause it sounds sick, manual, and suspension mods
seriously though do suspension mods till you can afford a 4age :thumbsup:
Share this post
Link to post
Basic mods are timing, exhaust and extractors, holden gemini carb.
If you want some fun mod an ac bracket to put an sc12 on, box up the carb, carter black fuel pump and a 1:1 fpr. Will be a bit of fun but you'll probably wish you just 4aged it
Share this post
Link to post
Ok awesome thanks guys...
So ive found a 4age Cheap!!!!!!
Now what gearbox should i use??
What fits easiest and cheapest??
Will a particular box match my motor and tail shaft?
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
